Air Conditioning
Old Jul 9, 2007 | 02:23 AM
hillfam4's Avatar
hillfam4
Default Air Conditioning
2000 Sport 4x4 3.9 5 speed 109,000 mi.
When the outdoor temperature is 85 deg. or more the A/C will only work intermittently. More off then on. The A/C works perfectly at around 85 deg. or cooler. The refrigerant charge is good. The high side and low side pressure is normal. I replaced the low side cycling switch and there was no change. I jumpered the high pressure switch, no change. If I turn the A/C off for a few seconds and back onit will start cooling, (sometimes).There are no trouble codes set. Any ideas ? or experienced this problem ?.
Old Sep 7, 2007 | 10:57 AM
sp1446's Avatar
sp1446
Default RE: Air Conditioning
I'm having the same problem. Have you figured it out yet?
Old Sep 7, 2007 | 02:36 PM
RP Racing940's Avatar
RP Racing940
Have the compressor checked.
Old Sep 8, 2007 | 01:59 PM
imnothot02's Avatar
imnothot02
+1 also could be just the clutch going out...how often does it kick on and off and is it a click on or a idk lol a not click on sound...
