Quadcab Drivers side rear power window???
Old Jul 11, 2007 | 05:13 PM
2002Dakota4.7L's Avatar
2002Dakota4.7L
Default Quadcab Drivers side rear power window???
Can anyone enlighten me on why intermittently my drivers side rear window will not go up when I hit the switch. If I hit the switch a couple times it will eventually go up. Comes down with out hesitation. Bad switch, window motor has dead spot on armature, bad ground? Any one else have a similar problem.
Old Jul 11, 2007 | 10:33 PM
Spidaman TNMC's Avatar
Spidaman TNMC
Default RE: Quadcab Drivers side rear power window???
i sorta have the same problem....my window has to go all the way down before it comes up....but urs sounds like a bad switch
Old Jul 14, 2007 | 01:20 PM
2002Dakota4.7L
I will have to test the switch and troubleshootsomeday. Any one know a price on the drivers door switch. I rarely have anyone in the back seat so I am not sure if the rear door switch is working correctly.
Old Jul 23, 2007 | 10:13 PM
2002Dakota4.7L
OK so after some checking it seems that the drivers doorwindow switchis to blame. Problem has not been replicated when I use the door switch in the rear. Only happens with the drivers switch. So now I am guessing I need to replace the whole drivers door switch on a QC. Any one have a price on that?
Old Jul 24, 2007 | 09:32 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
really expensive
umm not not really, but my moms durango has the same problem, not i know what it is thanks
Old Jul 24, 2007 | 11:33 AM
f0x672's Avatar
f0x672
i would guess around $80-90 from the stealership
