275s...
275/60
i coulda gone bigger in the back tho...but w.e looks better....i dont need the gas milage reduction
the front and back are dopped....front already rubs...
the sad part is. the tire did rub. shaved it down a lil the it cleared...and noww the inside of the rim rubs the a-arm when turning left...its bad.
metal on metal rub = no beuno
haha i cnt even pull 2 digits worth of gas milage in the city.
i found the trick for the r/t tho...its annoying but juss keep thinkin about the money ur saving while you do it.
2000 rpms on the freeway is pretty much prime gas milage.
granted ur only doin about 61mph and trucks are passing you.
oneven groundu can get anywhere between 20 and 30. air conditioner takes about 5 mpg. but opening ur window is pretty much the same so i go with the ac
and downhill u can pull into the 40s.....haha pretty much all i do is watch the mile per gallon reading move up and down and it makes the trip go by faster
i found out goin down hill....pop it into neutral and u get like 80 sumthin hahahah
lol ive been driving 120 + miles a day to and from my old house.
it gets boring
u can only listen to the same cd so many times before u throw it out the window
it gets boring
Trending Topics
ORIGINAL: chris0211
dam aint that a bitch! you even waste gas throwing it out the window.. you just can win..lol
no no i make sure i turn off the a/c before i open a window.
kinda equals out.
if your worried about gas.. you shoudn't have bought an R/T... I use 93octane and fill up every 4 or 5 days, around 200-230 milesper fill up, 60$a tank, 4 or 5 tanks a month.. 240-300++$ a month on gas 93 is about 3$ here.. somtimes it gets up to 3.10 or so...
