Window regulater
Old Jul 13, 2007 | 03:17 PM
Red4.7's Avatar
Red4.7
Default Window regulater
So i went to lunch today ad rolled my window down when i left . got there at tried to roll it back up and it didn't !I have already replaced it once since i bought the truck ! has this happened to anyone else
Old Jul 13, 2007 | 03:36 PM
Chris's Avatar
Chris
Default RE: Window regulater
Did you use an OEM regulator or an aftermarket?
Old Jul 13, 2007 | 04:10 PM
mmaloney's Avatar
mmaloney
I posted earlier about the same problem. I have an 04 Dak Quad cab 2wd. I have had 3 of the 4 window regulators go out. Started just after warranty expired then 9 month after that 1 would go for no apparent reason.Then 9 months after that another.
It's an expensive fix, about $400.00, part alone is about $280.00. I just wrote a letter to Dodge hopeing to get some answers, we will see what they say, if they reply. I live in Arizona where summer temps are very hot, I've had 1 service tech tell me that the heat could be the cause.
If you find anything out please post so I can read.
Old Jul 13, 2007 | 04:36 PM
Red4.7's Avatar
Red4.7
I got a oem replacement from carquest . Damn thats expensive mine was 100 and i had a buddy put it in for me . its nor really all that hot here so i really dont know what caused it
Old Jul 17, 2007 | 08:51 AM
dualdakota01's Avatar
dualdakota01
just switch to manual roll up windows lol. jk. yah i had that happen with my old mustang. ended up just being the ground wire wasn't attached. its probably not that but its a possibility.
Old Jul 17, 2007 | 09:56 AM
Razorhorn's Avatar
Razorhorn
Buddy of mine has a 2001 Quad 4.7L and he's had to replace three of them. So far, mine have been ok.
Old Jul 17, 2007 | 10:14 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
all of ours have been ok to date, but i think the back drivers doors one in my moms durango is going bc it has random times when it doesnt work, and then it starts working again
Old Jul 17, 2007 | 09:05 PM
V8Boss's Avatar
V8Boss
Had to replace the driver side. It started slowing since I got it then it eventually just crapped out. I wrote it off as normal wear and tear.
Old Jul 17, 2007 | 09:38 PM
Spidaman TNMC's Avatar
Spidaman TNMC
welll
i have a window problem now
the drivers side works fine except u have to go all the way down before you can go up again
Old Jul 19, 2007 | 10:34 AM
mplue's Avatar
mplue
I had the drivers side go out, but the cable actually broke something in there and came off the rollers. I bought an aftermarket regulater and it worked for about 3-4 months and it did the same thing. I called them back and they refunded everything except shipping. I ended up spending the big money and got an OEM regulator at employee price (25% less than what the dealer wanted) and installed it myself. Took me maybean hour to get the old one out and new one in. You'll need to cut a piece of wood to support the window. Believe this is the place I got mine, http://www.wholesalemopar.com/.
