Correcting For gear Change!
Old Jul 14, 2007 | 08:51 AM
KDedrick's Avatar
KDedrick
Default Correcting For gear Change!
Hi there,
I'll be puttin a set of 4.10's in my truck in the spring and need to find a way to correct the speedometer for it. how can this be done? any ideas?
Thank you,
Kyle
Old Jul 14, 2007 | 08:58 AM
dhvaughan's Avatar
dhvaughan
Default RE: Correcting For gear Change!
its my understanding that the speed sensor reads the revolution of the tone ring on the ring gear - which is directly attached to the axles, wheels, and tires. and that changing gear ratios has no effect on speedo, but changing tire and/or wheel sizes does. that's why the hypertec speedo correction only asks one question.. what is your tire diameter.
good luck on the 4.10's, i think you will really like them.
Old Jul 14, 2007 | 11:52 AM
superdak05's Avatar
superdak05
you will love the 4.10 i went from 3.55 to the 4.10 and what a difference. speedo is not off but the rpm are 300 difference now. also becarefull in the rain. i had to learn how to drive again because evey traffic light or stop sign i would come off the line spinning. so easy on the take off until you get use to them.
Old Jul 14, 2007 | 01:28 PM
V8Boss's Avatar
V8Boss
This is something I want to do also. Havent really looked into it too much. Just curious of a ballpark of how much it will cost, where should I get it done at, and do I need to buy the gears then take it somewhere or would the shop that I get it done at have all the parts?
Old Jul 16, 2007 | 08:54 AM
KDedrick's Avatar
KDedrick
i got a set of Richmond Sportsman gears from summit at about $190, plus a cross chaft $40, plus the install kit $125..plus install, probabaly somewhere between 200-400.
Old Jul 16, 2007 | 11:46 AM
rtkota5point9's Avatar
rtkota5point9
I'd say closer to $400-$450 with installation. Check with Sam atSoCalDakota.com He has gears with the install kit as a package that might save you some money.
Old Jul 16, 2007 | 04:12 PM
KDedrick's Avatar
KDedrick
SoCal's only got gears for 9.25 rear ends no 8.25's
Old Jul 16, 2007 | 04:31 PM
rtkota5point9
Aaaaah
Old Jul 16, 2007 | 05:53 PM
Durango911's Avatar
Durango911
Make sure you buy a decent brand of gears. I bought Motive and haven't had any problems. It costed me around $900-1000 for both gear sets/auburn posi unit. I had a friend install them so labor was pretty much FREE! I got my setup from www.nationaldrivetrain.com but I think www.ringpinion.comis probably cheaper.
Old Jul 16, 2007 | 10:38 PM
dhvaughan's Avatar
dhvaughan
check here. http://www.performanceoffroadcenter.com/
