Please help 1998 dodge dakota
Old Jul 17, 2007 | 05:21 PM
DLdodge's Avatar
DLdodge
Default Please help 1998 dodge dakota
My 19998 Dodge Dakota will not start. We thought it was the battery at first and tried to jump start it. That helped somewhat but as soon asI let go of the key and the gas peddle the car would die.I put a new battery in just in case however that did not work. Mydad, whom is a master mechanic, believes it is the fuel filter and pump. Please help! Thank you! [:@]
Old Jul 17, 2007 | 08:56 PM
imnothot02's Avatar
imnothot02
Default RE: Please help 1998 dodge dakota
check ur fuel psi first...
Old Jul 19, 2007 | 03:02 PM
rtkota5point9's Avatar
rtkota5point9
As long as you keep your foot on the pedal will it run fine? If so Clean or replace your IAC in the throttlebody. It's held on the back with 2 screws and 1 plug. It's the Idle Air Control plunger.
Old Jul 20, 2007 | 11:57 AM
Chris's Avatar
Chris
Oddly enough this happened to me this morning. I ended up having to drive my girlfriends car into work this morning, as I didn't have time to try and diagnose the problem. Seems to me that I will have to crack a couple cold ones when I get home.
Old Jul 20, 2007 | 01:26 PM
Chris's Avatar
Chris
Has anyone had any luck w/ this yet? I will have to fix this when I get home tonight and any info would be great ahead of time.
