water damage!!!
Old Jul 18, 2007 | 01:46 PM
dakdriver06's Avatar
dakdriver06
Default water damage!!!
ok so...my passenger side floor board is wet(not soaked,but pretty damp!!) why could this be happening??? i also got water dripping form the roof in the back seat??? help!!!!!!!!!!! thanks!
Old Jul 18, 2007 | 01:48 PM
OneBadKota's Avatar
OneBadKota
Default RE: water damage!!!
The floor board could be a bad heater core.
If not the heater core, I would check the weatherstripping on the passenger window(s)
As for the back seat,if you have a sliding back window, they're notorious on Dodge trucks for the weatherstripping going bad and causing to leak.
Hope this helps.
Old Jul 18, 2007 | 01:52 PM
dakdriver06
ok thanks!!! what is a heater core?, and where is it located!! ha thanks!
Old Jul 18, 2007 | 01:59 PM
OneBadKota's Avatar
OneBadKota
Here's some info for you, http://en.wikipedia.org/wiki/Heater_core
I would smell it first, if it doesn't smell like antifreeze, it most likely isn't the heater core. It could just be your weatherstripping needs to be replaced.
It's been awhile, but I think it is located under the glovebox of the truck.
Old Jul 18, 2007 | 02:32 PM
OneBadKota's Avatar
OneBadKota
I found this in the DIY section, if in fact it is your Heater Core..
https://dodgeforum.com/m_832803/tm.htm
Old Jul 18, 2007 | 02:35 PM
Captain Squalus's Avatar
Captain Squalus
ORIGINAL: dakdriver06
pass floor could be a plugged condinsate drain on the A/C
Old Jul 18, 2007 | 03:46 PM
Chris's Avatar
Chris
If it smells like coolant, then your heater core is leaking. If it doesn't have an odor than your A/C condesnation line is either plugged, or has been pulled into the cab. Pull up the carpeting on your passenger's side and make sure the hose is running out through the floor or firewall.
Old Jul 18, 2007 | 04:02 PM
Captain Squalus
ORIGINAL: virused
soom of the A/C drains are located on the engine side of the firewall
Old Jul 18, 2007 | 04:38 PM
dakdriver06
ok thanks guys you've been a big help!! i'll try all of those things and get back to you!!! thanks again!
