brake size
Old Jul 18, 2007 | 03:58 PM
jonnymagnum's Avatar
jonnymagnum
Default brake size
I just ordered new brakes. and I did not get ceramic pads cause they were waaaay too expensive[:'(] but anybody know what size of brakes go on the rear of a 8.25 axle? there was either 9" or 10" brakes. I went with 10". so I hope I'm right
Old Jul 18, 2007 | 08:15 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
Default RE: brake size
beats the hell out of me, but let us know if you were correct
better for me if i let someone else screw it up before i need to do the job
Old Jul 18, 2007 | 08:24 PM
DAKNBLK's Avatar
DAKNBLK
rockauto.com lists both 9 and 10 inch as proper fitment. Manual says the 'maximum' size is stamped on the drum. I would say since it lists a 'max' size, and from what rockauto says, you are probably good to go.
Old Jul 18, 2007 | 09:11 PM
f0x672's Avatar
f0x672
i know under my vin in stamped for 9.25 rear drums.. so in other words its 9 inches
Old Jul 19, 2007 | 02:57 PM
jonnymagnum
ya, I picked them up today and I'll be doing them this weekend. so I'll let ya know how it goes
Old Jul 20, 2007 | 01:23 AM
Rakaric's Avatar
Rakaric
ORIGINAL: jonnymagnum
I just ordered new brakes. and I did not get ceramic pads cause they were waaaay too expensive but anybody know what size of brakes go on the rear of a 8.25 axle? there was either 9" or 10" brakes. I went with 10". so I hope I'm right
The size should be listed on the door of your glovebox. Either there or in between the door and the ext cab.
Old Jul 24, 2007 | 03:29 PM
jonnymagnum
well......... I was wrong
it has 9" brakes on the back. and since I tore it all apart sunday I had to wait till monday for them to open to get the right back brakes.
and it drives sooo much better with my new wheel bearing too now
