lets talk intake manifolds for the 5.9/ 5.2
Old Jul 19, 2007 | 04:07 AM
5 speed's Avatar
5 speed
Default lets talk intake manifolds for the 5.9/ 5.2
im seriously in the market for an intake manifold and i need some advice from people who actually have one on their truck, i have a 99 5.2 5 speed with headers full exhaust 3.91 gears K&N FIPK and i plan on doing the intake manifold and throttle body in the next week or so.
heres my options:
M1 MPI 2bbl- ($465 + $69 install kit)i want it but i constantly read bad things about it (loss of low end)
Hughes stage II ported beer barrel- alot of money for a worked over stock intake ($465+ core) and does it really work? i havnt read anything about it except on the hughes website and of course there going to say its good
Hughes modified edelbrock air gap for MPI 2bbl- a TON of money ($725) for what your getting but theres a write up stating they gained almost a half secon in the quarter from the intake swap alone
any others? im only aware of those 3, and does a B&G flash help with the loss of low end on the M1? im about 10 miles away from there shop
Old Jul 19, 2007 | 07:22 AM
Durango911's Avatar
Durango911
Default RE: lets talk intake manifolds for the 5.9/ 5.2
I'm porting/polishing my "Keg" intake right now. If you have the $$$ I would go with the Hughes FI Airgap intake. That thing will out perform anything on the market. I was going to buy the airgap intake but I went withtheir bigger cam(HER1828AL), ECU re-flash, performance damper & flexplate. I even had the ecu re-flashed for that airgap intake because I know as soon as I get the $$$, I'm going to buy it! If you keep on planning to mod your truck, re-flash it at the end of your mods, it'll save you a ton of $. As far as the M1 goes, I heard it sucks till you get to around 3,000 RPM's and then it pulls really hard. That airgap intake is supposed to pull throughout the entire RPM range.
Old Jul 19, 2007 | 02:46 PM
rtkota5point9's Avatar
rtkota5point9
I think the M1 is a great manifold. Yes you do lose some low end. It actually starts picking up around 2300-2500 RPM, not 3000. With a gear change you can usually get some of that low-end back anyways. Our engines (5.2/5.9) lack quite a bit in the upper ranges, they just rev, but aren't pulling anymore. The M1 moves the powerband up enough to have a "happy medium".
I've heard good things about the Hughes too,never had any hands on with it.
Old Jul 21, 2007 | 12:38 PM
5 speed's Avatar
5 speed
anyone else?
