Holy wow replacing the plenum gasket is a B$%^#!
It would definitely be easier if I did it again (I had to remove tons of stuff to get to the temperature coolant sensor that was damaged) but man... the AC unit was a bit of a pain in the but as well.
Anyways, I'll give the truck a while, and a tank or two of gas to see if the results are noticable. At the very least I've done some major preventative maintence
