knocking noise uphill?
Old Aug 4, 2007 | 01:38 AM
dodgetruckpimp's Avatar
dodgetruckpimp
Default knocking noise uphill?
i've got a 99 dakota 5.2L and lately i've been noticing when i accelerate hard or drive uphill it will knock does anyone have any suggestions on what could be causing this knocking noise. thanks in advance
Old Aug 4, 2007 | 07:56 AM
dapirate559's Avatar
dapirate559
Default RE: knocking noise uphill?
any mods to the engine? what grade gas you buying? what kind of gas station do you buy your gas?
Old Aug 4, 2007 | 10:59 AM
Durango911's Avatar
Durango911
It sounds like the intake plenum gasket.
Old Aug 4, 2007 | 04:40 PM
dodgetruckpimp
super unleaded from different gas stations kwik trip, fleet farm, conoco. i also got a k&n air filter if that helps?
Old Aug 5, 2007 | 04:47 AM
dapirate559
the k&n just clogs up ur intake manifold. loo out for that. as far as the knocking it could also be a stuck lifter. try some mystery oil. you can get it at a local auto store. pour it into your oil and that might do it.
Old Aug 5, 2007 | 10:13 AM
superdak05's Avatar
superdak05
if those are mom and pop gas stations then it would say it is the gas. when was the last time you ran fuel injector cleaner threw the system. these trucks have knock sensors to prevent that. also you could have an 02 sensor going and it is not telling the computer
Old Aug 5, 2007 | 07:44 PM
dodgetruckpimp
no these are not ma and pa gas stations for the most part, and i run a can of sea foam threw my tank about once a month.
Old Aug 6, 2007 | 03:46 PM
rtkota5point9's Avatar
rtkota5point9
What you are hearing is Spark Knock. Not uncommon for our engines. Either cheap gas, or more likely the plenum gasket is badas already was stated. A bad plenum gasket lets oil into the intake manifold, it's then sucks into the cylinders andburned, the oil being burned is what contributes to the spark knock under a load. Check down in your intake manifold and see if there is a film of oil at the bottom. Just open the throttle blades with the intake hat off and peer down in there with a light.
Old Aug 7, 2007 | 12:57 AM
ElChango's Avatar
ElChango
I've had that issue before, only would notice it with ARCO gas for some reason, ever since then stayed away from that stuff and went away.
My vote is the gas.[:'(]
Old Aug 7, 2007 | 01:14 AM
dapirate559
ya i think so too. maybe you should try an octane booster when ou put gas in there. who knows.
