water on floor - finding the leak(s)
I bought a 2002 Dakota SXT last November. I've now found a LOT of water on the floor, under the rug & rubber pad. Any help on locating the leak(s) would be appreciated. We did locate 2 seams on the frontpassenger side that were not spot welded at the factory and water is dripping out through one or two spots there. We're going to fix that as well as silicon seal the gasket around the a/c drain where it goes into the firewall. BUT there's so much water, including under the back seat in the jack compartment; there's got to be a major leak somewhere.
