New Throttle Body and 1.7 Rockers
Old Aug 5, 2007 | 02:08 PM
aiu0462's Avatar
aiu0462
Default New Throttle Body and 1.7 Rockers
I just ordered the Fastman 48 throttle body and the Harland Sharp 1.7 rocker arms. Anyone have any idea how much HP increase? Looking to improve my gas consumption. Anyone done these? Reports?
Thanks,
Steve
Old Aug 5, 2007 | 04:14 PM
superdak05's Avatar
superdak05
Default RE: New Throttle Body and 1.7 Rockers
i went with the fastman 70 mm for my 05 4.7. works great. as far as the rockers they are suppose to be really god mod. tricks the motor thinking it has a bigger cam. should see some good gains in the seat of the pants dyno. try and get a dyno run before and after. you should pick up 10-15 more horses.
Old Aug 5, 2007 | 04:30 PM
User's Avatar
User
TB will give you better Throttle response, you wont feel much "*** dyno" power,
but th 1.7 dont really "Trick" anything, they actually let the valves open farther up to get the full potental of the heads, 1.6s dont let them open up all the way.. you can do 1.7s and get alot of power avg is about 17hp to the ground, depening on other mods.
Old Aug 6, 2007 | 07:32 AM
98R/TDak's Avatar
98R/TDak
sorry for a stupid question but can u put the 1.7 rockers in a totally stock engine and have them work fine besides needing higher valve covers?
Old Aug 6, 2007 | 08:33 PM
User's Avatar
User
yes you can, it would help the rocker mods out if you had a better flowing exhuast..
what the rockers do is open up the valves farther and longer, having headers and a free flowing exhuast will help out alot.... but you can run them on a stock engine fine.
Old Aug 7, 2007 | 09:41 PM
englitrob's Avatar
englitrob
Does changing the rockers affect interfierence between the valves and the pistons? I'm not sure if the 5.2/5.9 is an interfierence engine or not, but it would be a little piece of mind to know that if my timing chain breaks it won't destroy my engine.
Old Aug 8, 2007 | 12:22 AM
User's Avatar
User
do you have a 4.7? If you do.. then you do know that they come stock with 1.7s rockers right? Not 1.6s..
Old Aug 8, 2007 | 12:40 AM
englitrob's Avatar
englitrob
I have a 5.9. I'm not sure how similar the architectureof the 4.7 and the 5.9 is.
