how would you spend $2500?!?
Old Aug 13, 2007 | 11:51 PM
rred's Avatar
rred
Default how would you spend $2500?!?
how's it going everyone? i'm hoping i've found a good forum for getting insiteful information for my dakota.
-if you had a graphite grey stock 2002 dakota, club cab, 4X4, V6 how would you spend 2500 bucks on your new truck?
i'm not a big fan of the under powered V6 but it works for now. i'd like to get more power out of it, but i don't want to sink a whole lot of money into it right now. i'm thinking it would be cheaper to get a V8 out of a wrecked dodge down the road from now. i think i'm going with the Fireston Destination M/T tires in a (285/75-R16). i've read around and they should fit without to much rubbing. the stock tires are wrangler (265/75-R16) which is 1.18" shorter in the overall diameter and .79" narrower in the section width different from the new tires i want. the tires get great reviews and i can have them mounted and out the door for $685! i'd like to do a 3" suspension life. but i'm not about to drop 1400 for one. if i find one cheap on ebay, okay.
how would you guys blow the rest of the 2500 bucks?
[IMG]local://upfiles/70430/F1D80B7238DD4BB58D3A05BB38CEE9A8.jpg[/IMG]
[IMG]local://upfiles/70430/890945EC8E7440039285198FF3E9B60D.jpg[/IMG]
Old Aug 14, 2007 | 12:36 AM
superdak05's Avatar
superdak05
Default RE: how would you spend $2500?!?
i would swap out the gears for a nice set of 4.10. i had the 3.55 and went to the 4.10 great improvement 1600.00 out the door 4 wheel drive. next i would upgrade my throttle body. www.thefastman.com has what you are looking for. these two mods will help with the overall get up and go of the truck.
Old Aug 14, 2007 | 12:44 AM
jk240sx's Avatar
jk240sx
i would invest in a cheap body/bed lift kit, buy 32 tires that fit my rims, do a 4.10 gear as suggested. look over the suspension and basic maintanence and spend the rest on cheap hookers, rubbers, beer and tattoes. if you are on a budget with whats left, forget the rubbers and tatooes.
Old Aug 14, 2007 | 01:03 AM
TheePlaymaker's Avatar
TheePlaymaker
i can say those are great tires i had them on my cherokee and never got stuck did some good mudding in them too they have worn really well too still on it after35-40ish thousand miles...kinda noisy but if ur goin with an mt i dont think u really care also they are really loud on pavement if u ever do a burnoutjust backing up what u've read that they are a really good all around tire for mud, dry roads,snow and for the most part rain.
Old Aug 14, 2007 | 01:24 AM
Frenchy's Avatar
Frenchy
ORIGINAL: jk240sx
Funniest ****, I've read in a LONNNNNG time!!!!!!!
Old Aug 14, 2007 | 01:26 AM
rred's Avatar
rred
cheap hookers can be fun . . .
i'm not sure what the stock gears are. anyone know? i'd like to maintain the best gas milage possible. i know it's a fine line to try and maintain. maybe some 3.73s. i guess it depends on the stock gear ratio for me to determine there worth.
also, i'm not at all a fan of the gap thats caused by body lifts. i know there cheap to do. i'd do 3inches with new bumpers.
good stuff, keep the ideas comin
thanks
Old Aug 14, 2007 | 01:52 AM
superdak05's Avatar
superdak05
i think a blow up doll would be great, just incase you need to cruise down the diamond lane, you can inflate your date and be legal. also i dont like the wheel gaps between the body lift. unless you install gap guards. i think your stock rear might be 3.92 check in the glove box. there should be a sticker at the back descibing what the truck has in it. if not go to any dodge dealer and give them the vin. # they will be able to tell. or go to www.allpar.com and look it up under there vin decoder
Old Aug 14, 2007 | 08:43 AM
rred's Avatar
rred
thanks man
Old Aug 14, 2007 | 12:12 PM
Durango911's Avatar
Durango911
I guess it depends on what you use your truck for. It looks like you like to go off road but yet you still want to keep it as a daily driver? If I was stuck with a v6 and had $2500, Id get the following:
Ported Intake $400 http://www.hughesengines.com/partDet...amp;eTypeID=10
Throttle Body $225 http://www.thefastman.com/Throttlebodies39.asp
Spark Plug Wires $50 http://store.summitracing.com/partde...p;autoview=sku
Spark Plugs $20
Hypertech 180 T-stat $11
Flowmaster Muffler/High Flow Cat $200-300
Headers $466 http://store.summitracing.com/partde...p;autoview=sku
K&N Cold Air Intake $300
Underdrive pulleys $130
ECU REFLASH $300
Worry about new tires/gears later![sm=trust_me.gif]
Old Aug 14, 2007 | 12:50 PM
rred's Avatar
rred
i deffinetly don't think i'm going that route. i could find a used V8 and drop it in for that amount.
