Dakota RT Durango RT horsepower?
Old Aug 14, 2007 | 10:06 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Default Dakota RT Durango RT horsepower?
I wanted to know if anyone knows how much horsepower and torque a Dakota RT and Durango RT make. I know the 5.9 in the ram makes 245Hp and 355TQ I belive? But does the RT models make anymore than that? And if they do why do they. Is it the computer? Is the Engine and Injectors all the same or what?
Old Aug 14, 2007 | 10:14 PM
User's Avatar
User
Default RE: Dakota RT Durango RT horsepower?
Stock 5.9 R/T Dakota pushes.. 250hp/340torque at crank... R/T came with a PCM flash kinda like what the Tow package gets, shorter gears, advance timing.. ect...
Old Aug 19, 2007 | 11:56 AM
Crazy4x4RT's Avatar
Crazy4x4RT
Thanks for the info!
Old Aug 20, 2007 | 03:56 PM
MulletsRT's Avatar
MulletsRT
the 5 extra HP comes from a different exhaust on the R/T. Has a free flowing exhaust compared to stock applications.
Old Aug 20, 2007 | 10:05 PM
Crazy4x4RT's Avatar
Crazy4x4RT
Oh okay thanks. Do you know what axle the rt came with and what raios?
Old Aug 20, 2007 | 10:59 PM
User's Avatar
User
ORIGINAL: MulletsRT
the 01+ R/Ts didnt have the free flowing exhuast 3x cats, the 98-00 had the free flowing exhuast. The Tune on the PCM was a towing tune the same as most of the big rams get.. thats where most of the power came from, advanced fuel sync and timing... exhuast does help.. but not that much.
ORIGINAL: dodgef25
The R/Ts Came with the 9.25 rear end and was equiped with 3.92 gearing..
Old Aug 21, 2007 | 09:40 AM
Durango911's Avatar
Durango911
I agree with everything you said except for the fuel sync. All dodge vehicles are set to "0" even if a performance cam is installed unless you request the dealership to change it. And most dealerships,even 5 star, don't know what a fuel sync is. They have to get out their fancy little books and look it up...pathedic!
Old Aug 21, 2007 | 10:54 AM
User's Avatar
User
ORIGINAL: Durango911
Ya dealerships don't know ****. When i had my Secuirty Mopar PCM, they told me the PCM was nto for my truck and would not work, yet i told them to look at the pN and what do you know.. 2000 Dakota 5.9 Fed 4x2 PCM... dumbasses.. they also tried to tell me that my truck was NOT under warrenty for the upper ball joint recall.... again i had to bring in evience to show them that im right..
Im only 20 years old, and im pretty sure they think im just another ****ing stupid ***.
o and about the fuel sync. Yes most are set to 0.. but if you ever have a chance, take a look at the stock PCM setting for a Dakota R/T... its actually set at +3. Mines at +6 right now, and im having bad problems with backfire and lowend bog. Im about to rotate the damn dis. and keep checking it till i get it to about +4 or 3.. The dealership would want like 90 an hour to redo my sync... and it would take them 4 hours just to figure out how to do it..
Old Aug 21, 2007 | 11:02 AM
Billiam's Avatar
Billiam
They both put out near the same it not the same don't they? I know the Durango is on the Dakota chassis, so I would assume they'd probably have the same power. But I could be wrong, its all a guess.
Old Aug 21, 2007 | 12:03 PM
Durango911's Avatar
Durango911
I've never seen a "stock" dodge, even R/T, with the fuel sync at +3. They were always at "0" unless someone messed with the distributor. Mine is ranging from +3-6.(on snap on and chrysler scanner)I just did a fuel sync on my neighbors 1999 Dakota R/T.(we put a cam in it) It was at "0" to start with and we put it at +2-4.
