No Shift out of 1st?????
Old Aug 16, 2007 | 07:56 PM
spikejeff's Avatar
spikejeff
Default No Shift out of 1st?????
[8D][X(]New to the fourm as a poster, been reading and Thanks to all who have had things happen and share the "fix's" here.
2002 R/T, Fast man TB,K&Ncone and pipe.When at WOT in drive, tranny does not shift out of 1st gear. 54-5500 PCM starts cutting fuel off, I have been unable to find a fix, TV cable has been set-up per tech sheets, TPS is set at .69v at rest position. Thanks to all who can help . Jeff
Old Aug 16, 2007 | 08:40 PM
imnothot02's Avatar
imnothot02
Default RE: No Shift out of 1st?????
solonoid?
Old Aug 16, 2007 | 08:46 PM
spikejeff's Avatar
spikejeff
Failed to mention, no codes showing.
Old Aug 16, 2007 | 10:26 PM
bigbaddurango's Avatar
bigbaddurango
I just had the same thing happen to my durango it was the speed sensor in the transmission whent to dealer it was 38 bucks i think az couldnt get it
Old Aug 17, 2007 | 09:06 AM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would secound the speed sensor on the tranny, and if you go the local auto store its like 20 bucks, at least around here
Old Aug 17, 2007 | 03:05 PM
spikejeff's Avatar
spikejeff
I will give the speen sensor a try and post the results, thanks for the input.
spikejeff's Avatar
spikejeff
or should I say SPEED sensor....
