My Tranny Fix
My Tranny Fix
2002 R/T, Problems with converter lock and unlocking. Check voltage on TPS,,.5v installed new one,.6v, modified old one-drilled out brass mounting sleeves- indexed it to spec,.7v. Set up TV cable to factory spec. Problem went away. Made a move on cable--still no problem-- re set cable to specs. Showed TPS was the real problem. To bad dealer$hip did not do this, they replaced tranny and torque converter prior to me correcting REAL problem.Thanks for an extended warrenty. Thought I would share this to help anyone else with same problem.[8D]
RE: My Tranny Fix
i just purchased my first dakaota yesterday. have never owned a dodge before. got a 2002 5.9 R/T with 54,000 miles. love the truck but seems to have this exact same problem as posted above. seems fine till it goes to shift into 3rd gear. shifts from third to o.d. back to 3rd then back to o.d. all very rapidly. does this every time. what are your suggestions for someone with no dodge experience?
RE: My Tranny Fix
took truck back to the dealership that i bought it from. the mechanic drove it and felt the problem. they flushed the tranny, made no difference. what should be the next step?? any response would be appreciated. oh... i didnt mention that the dealership i bought the truck from was a chevrolet dealership (so they really don't have much of a clue on my dakota.)
