Bogging out
Old Aug 28, 2007 | 10:17 PM
batman13's Avatar
batman13
Default RE: Bogging out
good idea considering i just threw an o2 code today (after cat)
Old Aug 29, 2007 | 01:34 AM
dodgerules86's Avatar
dodgerules86
ORIGINAL: virused
I would replace the O2 sensors and clean the throttle body while you are at it.
+2.
Try using Mopar Combustion Chamber Cleaner (about $8 from the dealer). I was having a similar bog problem (with me, usually happened with engine cold), and used that, and the problem got better.
Old Aug 29, 2007 | 02:19 AM
jlking21's Avatar
jlking21
ordered the TPS and o2 sensor today, TPS was $82 and change from the dealer, downstream o2 from a local parts shop $64. i will use the combustion chamber cleaner when the parts go in, is that stuff a add in fuel tank??? hopefully this goes away, or i hate to say it "the dakota will be gone".
Old Aug 29, 2007 | 04:26 AM
dodgerules86
The Mopar Combustion Chamber Cleaner comes in an aerosol can, and you spray it into the throttle body.
Thecomputer might throw a code (mine did, for misfires, because it starts to make the engine run pretty rough), but the codes do go away by themselves. Just follow the instructions on the can.
Old Aug 29, 2007 | 08:27 PM
batman13's Avatar
batman13
$58 later...
changed the TPS, big improvement,
but not fixed.
I'm gonna clean the TB this week, see if I can get more improvements.
I wish I could get a bigger TB for my 4- cyl without selling the next kid
Old Sep 6, 2007 | 02:00 AM
jlking21's Avatar
jlking21
so i installed new parts today to try and fix my problem. installed downstream o2, tps, iac. after i put them in i started it up. everything seemed fine, waited till the truck was up to temp then shut it off. i waited 15 minutes and restarted it and bam rough idle again (PROBLEM NOT FIXED) what could be causing this??? could a plugged cat do this? i am just a little confused as it only does it right after starting when the engine is hot. any help would be greatly appreciated.
Old Sep 6, 2007 | 02:01 AM
jlking21's Avatar
jlking21
also, i took the tb off and completely cleaned it.
Old Sep 6, 2007 | 04:37 AM
batman13's Avatar
batman13
mine only does it when cold...
odd,
Old Sep 6, 2007 | 10:35 AM
varsis's Avatar
varsis
A clogged cat can do a lot of problems. I had one on mine. Took it off improved idle by about 75-80% I did put a new one on but high flow.
Old Sep 7, 2007 | 02:03 AM
jlking21's Avatar
jlking21
i am going to change the cat, soon. but now that i have put all these other parts in my budget is a little tight now. where did you get the high flow cat and about how much was is? i dont want to have to remove the whole pipe. if i can get away with cutting the old one out between the o2's and weld or clamp a new one in it would be great. is there any way to test to see if my cat is clogged???
