97 forgetting how to drink
Old Sep 12, 2007 | 02:42 AM
ironrosefarms's Avatar
ironrosefarms
Default 97 forgetting how to drink
My 97 with a 3.9 has been giving me fits. It stalled out last week and I found 0 fuel preassure at the fuel rail. Two days later I went out and checked for codes and accidently started it. Pump was back alive. Took off toward town only for it to stall out again about two miles down the road.
Drug it back home and replaced the fuel module (pump/filter/assending unit) and all was good for another week.
Then today I went out and it would not start. No fuel at the fuel rail again... grrrrrrr... I swapped around the fuel relay and auto shutoff relays with other relays in the power distribution box with no effect.
Anyone know the identification for the 4 wires going to the fuel module in the tank? and any other ideas why this thing is flaking out on me.
Thanks
James
Old Sep 14, 2007 | 01:00 AM
ironrosefarms
Default RE: 97 forgetting how to drink
Bump
Old Sep 14, 2007 | 01:24 AM
dodgerules86's Avatar
dodgerules86
Dark green/black - voltage from fuel pump relay
Black - ground
Black/light blue - ground (provided via PCM)
Dark blue/white - fuel pump relay control
Old Sep 14, 2007 | 01:59 AM
ironrosefarms
Thank you Dodgerules86.
My haynes manual does not list the wire colors, I sincerly appreciate your help.
James
Old Sep 14, 2007 | 02:04 AM
ironrosefarms
Uh, just thought of something, since the fuel pump and sending unit are both part of that module I am still not sure which wires do what? Any ideas?
Old Sep 14, 2007 | 02:10 AM
dodgerules86
From the wiring diagram I'm looking at, it looks like the pump motor gets it power from dark green/black, and ground from black.
Fuel level sensor = black/light blue for input, dark blue/white for output.
Old Sep 14, 2007 | 02:19 AM
rred's Avatar
rred
sounds like your fuel pump is bad. the truck is 10 yrs old. just a thought?
Old Sep 14, 2007 | 02:20 AM
rred's Avatar
rred
nvm, i lied. my bad. you'll have you excuse me. i'm on the midnight shift bored out of my mind and geeked up on caffine.
Old Sep 14, 2007 | 02:42 AM
ironrosefarms
rred no prob, fully understand.
dodgerules86 thank you again,
I'll check it out this weekend, I'm in the middle of a 21 hour work day... When I get off I'm going home to collapse for a day!
James
