Pcm swap test?
Old Sep 13, 2007 | 09:20 AM
yellowjacket99's Avatar
yellowjacket99
Default Pcm swap test?
I suspect my pcm may be the reason my cruise will not work. My truck did not come with cruise, but I bought all the factory parts and put them in.
My brother-in-law has basically the same truck. The only difference is his is a 2000 and mine's a '99, his is 2wd and mine is 4wd. Both are 3.9 automatics. His came with cruise. Would it be possible to put his pcm in my truck to see if the cruise will then work, or put mine is his truck to see if his still works? Which route would be better?
Thanks.
Old Sep 13, 2007 | 09:49 AM
superdak05's Avatar
superdak05
Default RE: Pcm swap test?
it will work but one thing. your truck did not come with cruise so your pcm must go to dodge and have them install the peramiters for it. any dealer is capable of doing this.
Old Sep 13, 2007 | 11:25 AM
yellowjacket99
From what I've read and been told it's usually a plug and play deal. Seems like they'd just make a standard pcm fora particular vehicle drivetrain/emissions combo with all options to put in all the vehicles.I took it to one dealer and they didn't believe that there was any way to turn that function on with their scan tool. They hooked it up and just said the pcm isn't seeing the button signal. So with what you're saying would that be considered having to get the pcm flashed, or just going in and modifying my current one?
Old Sep 13, 2007 | 01:17 PM
rtkota5point9's Avatar
rtkota5point9
He's right, you must bring your PCM to thedealer and have it flashed for the cruise to work.
Same thing with Fog lights, on some trucks if you add factory foglights you must get the PCM reflashed for them to work.
Old Sep 13, 2007 | 03:07 PM
yellowjacket99
Alright, thanks guys. Any idea how long that should take?
