ABS and E-Brake Light?
Old Sep 17, 2007 | 12:50 AM
varsis's Avatar
varsis
Default ABS and E-Brake Light?
Well, My ABS and Brake light are constantly stuck on. They don't flicker or anything just off all the time, does anyone know were the wiring is for this/ Ground Cables. I did work on the timing chain and these lights stay on.
Chris
Old Sep 17, 2007 | 09:45 AM
yellowjacket99's Avatar
yellowjacket99
Default RE: ABS and E-Brake Light?
Usually those lights mean that your rear wheel speed sensor is bad. You can check the wiring on connector 1 at the CAB, the 2001 manual shows it's wire's 1(RD/VT) and 8(WT/VT). If those are ok then I'd be looking at the sensor in the rear axle.
Old Sep 17, 2007 | 12:44 PM
varsis's Avatar
varsis
Okay, thanks!
Old Sep 17, 2007 | 04:34 PM
varsis's Avatar
varsis
ORIGINAL: yellowjacket99
How do u find this in the manual? I can't find it.
Old Sep 17, 2007 | 09:49 PM
master tech's Avatar
master tech
Site Moderator & Tech
What you should do is ck your fuses and if they are okay with a test lite, then ck for codes and go from there.
Old Sep 18, 2007 | 01:12 AM
varsis's Avatar
varsis
K I don't think any of the fuses are bad as I recently checked them but I will have a look.
Old Sep 18, 2007 | 10:37 AM
yellowjacket99
ORIGINAL: varsis
It's under wiring, then under rear wheel anti-lock brakes, pg. 8W-34-3.
