'99 Dakota Club Cab(?) rear speaker/Panel help!!??
[align=left]Hello, I am trying to figure out how to take the rear drivers side panel off (That covers the speaker). Because the speaker cover has fallen off and makes the spekaer sound horrible as the speaker presses up against the cover, But I cannot figure out how to take the panel off to get to the speaker???
Thanks!
Here are two pictures of it to show what kind of cab it is. =)
[/align][align=center] [/align]
Thanks!
they just pull off. there are just lil plastic clips that hold it on. you will probly end up snapping acouple of them in the process.
i took the back seat part off that should make it a little easier then just pull away kinda a bitch the first time but once you figure it out its not as bad lol. good luck!!
Just remove the rear seat by pushing up and pulling on it. It's held on by plastic tacs in the back. Once you remove that there should be two screws holding the side panels. You'll need to remove those before pulling on the rear side panels. Make sure you get all the plastic holders lined up to their holes when installing. Hope this helps.
I cant help you with your problem but i just wanted to say that you have a very slick truck, i like it a lot!
