Tranny question
Old Sep 19, 2007 | 12:54 PM
Pauls 00 Dak's Avatar
Pauls 00 Dak
Default Tranny question
First of thanks for all of the answers to the front end questions!!
Dodge Dakota trucks and for that matter trucks in general are new to me. I am however mechanical and have done and will do all of my work on my vehicles.
Ok my new question is I have a noise that appears to be coming from the trans axel area.
I have a code reader and there are no codes showing on the truck at all.
The 3.9 liter starts and runs great there is no noise until I shift into drive
then I get a rattle sound that is present while ideling and seems to go out under load. The truck shifts fine and the noise doens't seem to affect anything but I need to find out what the problem is.
Any ideas?
Old Sep 19, 2007 | 01:01 PM
Chris's Avatar
Chris
Default RE: Tranny question
Have you checked your tranny fluid level? I would suggest dropping the tranny pan and flushing the tranny. Change the tranny filter, replace fuild to correct level and enjoy.
Old Sep 19, 2007 | 01:05 PM
Pauls 00 Dak
The fluid level is correct and is a nice red color.
Do you think that a flush will take care of it? Cause I love the easy fixes!!
Old Sep 19, 2007 | 02:59 PM
varsis's Avatar
varsis
Could be something like a u joint.. But who knows...
Old Sep 19, 2007 | 04:07 PM
Twiztid's Avatar
Twiztid
just a rattling noise from around the transaxle? Maybe a loose heat shield somewhere.....heard of several guys having that issue...including myself.
Old Sep 20, 2007 | 12:46 PM
Pauls 00 Dak
I think that my noise is coming from my transfer case.
I couldn't find a loose heat shield but I do think the sound is coming from there.
I think I will change the fluids in there and see if that helps.
How much fluid and and what do I need? I think ATF+4 is this correct?
Thanks again
Old Sep 20, 2007 | 06:41 PM
DAKNBLK's Avatar
DAKNBLK
The ATF+4 is fine, and I'm pretty sure I used a 10mmhex on the plugs on mine.
Caps are:
Transfer Case,NV231..........2.5 pints
Transfer Case,NV242..........2.7 pints
The location of the fill plug is unhandy to try and pour the fluid in in any way, so, a cheap pump can really be your friend here.
Old Sep 20, 2007 | 06:50 PM
f0x672's Avatar
f0x672
crawl under there and start moving things around, check out your u joints, heat shield ( previously mentioned), anything and everything, nothing should be loose unless it was designed to wobble or so, etc
