console latch?
Old Sep 21, 2007 | 07:40 PM
magnethead's Avatar
magnethead
Default console latch?
Is it somewhat common fr the center console latch (front banch) to stick?
I basically have to use 2 hands to open it- I popped the cover off, and it shouldnt take but a 5th grader to realize that the angles the latch uses are impossible angles to deliver force through.
Is there a DIY type fix to file that lever or limit it's latching movementto where the angles are right but it still holds the lid when upright?
Old Sep 21, 2007 | 08:34 PM
magnethead's Avatar
magnethead
Default RE: console latch?
ok my dad and I just fixed it using a file, 2 1/4" pieces of rubber hose, and some superglue.
Old Sep 21, 2007 | 09:27 PM
Pauls 00 Dak's Avatar
Pauls 00 Dak
You guys sound like Mcgiver you just needed duct tape and a ball point pen
Old Sep 21, 2007 | 10:26 PM
magnethead's Avatar
magnethead
we used the hose to move the latch mechanism so that it stops 1/4 way from normal so when the handle is pulled it makes a better angle.
Old Sep 22, 2007 | 08:22 AM
imnothot02's Avatar
imnothot02
i lubed mine with lithium <sp> grease and its worked fine ever since, and yes this is common
Old Sep 22, 2007 | 09:10 AM
magnethead's Avatar
magnethead
ORIGINAL: imnothot02
we tried a bearing grease and graphite comination, didn't help at all.
