Tranny and Shift kits
Old Sep 23, 2007 | 03:21 AM
varsis's Avatar
varsis
Default Tranny and Shift kits
Well when my tranny was rebuilt a shift kit was put in. The problem is that sometimes i will be going 80 and it will want to kick down into 1st gear... This is because of the shift kit right? Just wanted to know. Im pretty sure they allow you to kick down into any gear at any speed.
Old Sep 23, 2007 | 09:30 AM
skeeter0288's Avatar
skeeter0288
Default RE: Tranny and Shift kits
i don't do automatics,but kickdown from 80 into 1st?that doesn't sound right.
Old Dec 27, 2007 | 08:28 PM
w9awx's Avatar
w9awx
from 80, it should kick down to 3rd, possibly 2nd depending on how the kit is designed.
Old Dec 28, 2007 | 12:29 PM
Twiztid's Avatar
Twiztid
I doubt it is going for 1st, maybe down too much, but not 1st.
you probably just need a band or TV adjustment.
Old Dec 30, 2007 | 12:50 AM
magnethead's Avatar
magnethead
first gear is a 3.00:1 or something deep liek that. It wont go that low. But 2nd down is a 1.67 and 2nd up is a 1.50..those are what it might be goin for (assuming you have a x45RFE)
Old Dec 31, 2007 | 11:34 PM
moe7404's Avatar
moe7404
Moe in Wichita Kansas
sounds like the valve body is leeking. or throlte linkage is out of adjustment or if it a cable, i have seen cable housingsgo bad and stop the cable from moving.
