Removing Cat.
Old Sep 25, 2007 | 10:42 PM
RJTDakotaBoy's Avatar
RJTDakotaBoy
Default Removing Cat.
So my cat is starting to go, it began making a really gross noise, so I am debating whether to replace or remove. Warranty is no issue. Cost is somewhat. I just want to know can I remove it and still have my truck run fine.It is a 2000 Dakota 4.7L 4x4.There isanO2 sensor on either side of the cat. CanI remove it without having the check engine lightalways on or poorrunning? Anyhelp or suggestions greatly appreciated
Old Sep 25, 2007 | 10:50 PM
imnothot02's Avatar
imnothot02
Default RE: Removing Cat.
search and you will find...https://dodgeforum.com/m_789836/tm.htm
Old Sep 25, 2007 | 10:59 PM
RJTDakotaBoy
ok... so it looks like I'll be fine. Can I remove the o2 sensor after the cat as well to prevent the Check Engine light?
Old Sep 25, 2007 | 11:44 PM
TheePlaymaker's Avatar
TheePlaymaker
just get a hi flow magnaflow cat off ebay and be done with it thats what i did and i have no problems what so ever.
Old Sep 26, 2007 | 01:29 AM
varsis's Avatar
varsis
Buy a fake sensor. They make the computer think you still have a cat... With no cat = better preformance, well bottom end might be an issue.
Old Sep 26, 2007 | 05:44 PM
imnothot02's Avatar
imnothot02
no cat doesnt = better performance... no cat=problems in the long run... do as pitkanen44flyers said if ur going for perfiormance
Old Sep 30, 2007 | 01:15 AM
jlking21's Avatar
jlking21
i did my cat today, replaced with a magnaflow high flow, just for kicks i unplugged the downstream o2 and started it, threw a code instantly. my truck idles soooo much better now and my power is back also. i wouldnt recommend punching it out or removing any o2's
Old Sep 30, 2007 | 11:44 AM
DAKNBLK's Avatar
DAKNBLK
jlking21, what is the part number for the cat. you got, and is your exhaust stock or modded?
Old Sep 30, 2007 | 11:56 PM
jlking21's Avatar
jlking21
part# 94606, i have heartthrob cat back duals. if you are planning on doing this you should have a bender to bend new pipe as my truck has a crossmember in the way and had to bend a new pipe to go over it and weld in new nuts for the downstream o2. kind of a pain in the ***.
