surging while driving.
Old Oct 9, 2007 | 11:15 AM
02dakotakid's Avatar
02dakotakid
Default surging while driving.
ok so my problem is that when im driving down the road the truck will surge and my tach will jump a few hundred rpm. i notice it more when the cruise is set. i think it may be either the throttle position sensor or my cruise control servo. any ideas?
Old Oct 9, 2007 | 12:17 PM
steve05ram360's Avatar
steve05ram360
Default RE: surging while driving.
I'd start with the TPS... noisey ones will caust the TC to lock & unlock causing a surging feeling
Old Oct 9, 2007 | 01:34 PM
4x4kota's Avatar
4x4kota
Mine does the exact same, let me know what you find for the fix
Old Oct 9, 2007 | 03:19 PM
steve05ram360
ORIGINAL: 4x4kota
your's is for sure going to be the TPS... 99% of the time that is what it is. there is 1 other possible failure which is a wire inside the tranny. since tps's are cheep and quick to swap, start there.
Old Oct 9, 2007 | 03:33 PM
4x4kota's Avatar
4x4kota
even though it only does it when i use cruise?
Old Oct 9, 2007 | 04:04 PM
Chris's Avatar
Chris
ORIGINAL: 4x4kota
You most likely have a loose vacuum line running off of your throttle body which controls your cruise control speed.
Old Oct 10, 2007 | 04:41 PM
02dakotakid
one of the guys i work with said it could also be the egr vavle. he said it was probly the tps though so as soon as i get the time im gonna check it
Old Oct 10, 2007 | 04:50 PM
steve05ram360
02 kid.. you dont have an egr valve... er, wait a minute, which motor do you have? not sure about the 4.7's but the egr's went byebye in '97 on the 3.9/5.x motors.
4x4Kota... check real closely w/o the cruise on to see if it surges. if you have a tach, you should see a 200 rpm change in the rpms. I havent heard of the vacuum line causing any problems on the cruise, but that doesnt mean it cant happen. I'd think with a vacuum leak you'd have real funky cruise operation...
