Starting Issues
Old Oct 11, 2007 | 01:38 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
Default Starting Issues
I have a 2000 dakota Quad cab with the 4.7 v-8. When i start it in the morning or when the engine is cold, it starts right up but after the rpms drop a little bit my engine starts idleing rough and the rpms drop to about 300 and then it jumps up to about 1500 by itself. I did a complete tune up thinking it might be my spark plugs. They were bad and needed to be changed but it didn't help. Anyone have any ideas what it could be? I have no check engine light on or any code so i am clueless. It runs fine other then the start up.
Old Oct 11, 2007 | 02:12 PM
06dak's Avatar
06dak
Default RE: Starting Issues
I don't have your answer - but I do have teh same problem ('00 CC 4x4 V8).
I start mine up, it starts at a normal high rev but then slowly comes down, starts running rough, than stalls. Yesterday I re-started and it ran fine. Today I gave it gas to keep it going, it took a couple shots before the idle settled to a good range.
I just bought it 2 weeks ago.
Any answers out there???
Old Oct 11, 2007 | 06:25 PM
1999dakota's Avatar
1999dakota
swing by a auto store and have them do a check eng light test. I had the same problem with my 99 6cyl. I needed to replace the map sensor and abs/speed sensor, now it runs fine...or it did before the t-case went out.
Old Oct 12, 2007 | 09:53 AM
MTN13's Avatar
MTN13
I have one of the scanners and plugged it in and nothing came up so i am still stumped. Thanks for the advice tho 1999 dakota.
Old Oct 12, 2007 | 11:19 AM
f0x672's Avatar
f0x672
go grab yourself a chilton's repair manual, try to stay away from haynes.... they suck
Old Oct 12, 2007 | 10:56 PM
MTN13's Avatar
MTN13
I have the chiltons have scanned through it to see if i can see anything but i haven't found anything yet.
Old Oct 13, 2007 | 09:39 AM
lidhead's Avatar
lidhead
hey i got the same prob on my '99 5.2L. on my truck the rpm's drop, the engine rev's up, then runs fine.i've tried cleaning the intake and lucas tune-up in a bottle nothing seems to work. i don't think its harming the engine so i just gave up. oh yeah i replaced my speed sensor too, for a different problem, maybe i should try the map sensor.
Old Oct 13, 2007 | 10:15 AM
imnothot02's Avatar
imnothot02
clean ur throttle body and the tps
