not a quick start up
Old Oct 15, 2007 | 11:06 AM
smorris1711's Avatar
smorris1711
Default not a quick start up
I have 2004 Dakota with a 4.7 engine. My problem is when the engine is cold it dosent start right up. The starter turns the engine over but it dosent fire off until it has turned the engine for several seconds. Its like the fuel has leaked down and it takes a few seconds for it to build up enough pressure to crank. I have been told it could be the fuel pump or fuel filter. Anyone have any suggestions?
Old Oct 15, 2007 | 06:08 PM
imnothot02's Avatar
imnothot02
Default RE: not a quick start up
have ur fuel psi checked, proaly a fuel pump you run it down lower than 1/4 tank of gas alot??
Old Oct 16, 2007 | 01:06 AM
JBs DAK's Avatar
JBs DAK
Yep, do a leak-down test.
My bet is it's the Fuel-Pressure-Regulator.
