Cat Problem
Old Oct 22, 2007 | 10:55 AM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
Default Cat Problem
Whenever I drive more than like 50-60 miles my check engine light comes on and it reads a P0420 (Catilitic Converter not preforming up to efficiency). Is there a way to take the cat out without causing the check engine light to come on all the time, or is there a way to fix the damn thing.
Thanks
Matt
Old Oct 22, 2007 | 12:36 PM
TheePlaymaker's Avatar
TheePlaymaker
Default RE: Cat Problem
http://cgi.ebay.com/ebaymotors/eBayI...m=270125672788
easiest way right there lol cheap to only 63 bucks for the new cat. not sure if thats your reason for the check engline ligth but chances are it is.
Old Oct 22, 2007 | 01:08 PM
varsis's Avatar
varsis
or buy sim sensor and remove cat. What engine do you have?
Old Oct 22, 2007 | 02:11 PM
Chris's Avatar
Chris
ORIGINAL: varsis
Or buy a new cat and not turn your daily driver into a gross poluter.
Old Oct 22, 2007 | 05:43 PM
steve05ram360's Avatar
steve05ram360
Or yank the o2 sensors and clean them. your cat is probably fine, check the o2's 1st. also you can test your cat by measuring the inlet temp & outlet temp... outlet temp should be hotter than the inlet temp by greater than 10* for smog purposes... not sure what the PCM is looking for.
Old Oct 22, 2007 | 06:18 PM
imnothot02's Avatar
imnothot02
how many miles on the truck, proaly due for a cat, kinda like timing belt/chain ect, general maint...
Old Oct 22, 2007 | 07:57 PM
lil's Avatar
lil
ORIGINAL: varsis
What is a sim sensor ?
Old Oct 22, 2007 | 10:04 PM
MTN13's Avatar
MTN13
Ok thanks for the advice guys. I have a 4.7 l V-8 with 126,xxx miles on it. It probably could use a cat but i'm leaving for college and need every penny i can keep. I do not think that it is a big deal i just hate looking at a check engine light. I was trying to make it a quick easy repair.
Old Oct 22, 2007 | 10:40 PM
imnothot02's Avatar
imnothot02
should help ur gas milage too
