Finally Removed the Headers...
Old Oct 22, 2007 | 02:18 PM
varsis's Avatar
varsis
Default Finally Removed the Headers...
Well I finally removed the headers from my truck and guess what? No gasket for them. Also no gasket were the headers connect the y-pipe. Does anyone know the size of the donut gasket? I don't have anything to go on and I need to know so I can get the right one.
Chris
Old Oct 22, 2007 | 04:05 PM
steve05ram360's Avatar
steve05ram360
Default RE: Finally Removed the Headers...
what headers are they? the flange side doesnt need one if they are gibsons... I had them on the 2000 gasser and worked fine. used the napa gasket between the header & head, also worked fine.
Old Oct 22, 2007 | 04:54 PM
varsis's Avatar
varsis
Got napa ones on the way. But these are the stock on the drivers side.
Chris
Old Oct 22, 2007 | 06:23 PM
imnothot02's Avatar
imnothot02
napa what headers?!
Old Oct 22, 2007 | 06:28 PM
varsis's Avatar
varsis
I ordered gaskets from napa but the headers are stock.
Old Oct 22, 2007 | 06:58 PM
imnothot02's Avatar
imnothot02
ah i was gna say
Old Oct 22, 2007 | 08:43 PM
varsis's Avatar
varsis
Does anyone know if there should be a donut gasket on the part where headers meet the ypipe also what size if so.
Old Oct 22, 2007 | 11:17 PM
imnothot02's Avatar
imnothot02
no
Old Oct 23, 2007 | 01:42 PM
varsis's Avatar
varsis
Well I put the headers in. Started it up there was a leak. But I suspect the part where the header meets the Y pipe. The gasket I used will probably form looked like graphite. But The problem was that As much as I cleaned the surface there was still the grooves from the headers being on the engine I hope these gaskets form up a bit. I cleaned it as much as I could but rust over the years added a couple of lips. Will this probably be okay? I think the problem is y as one of the bolts was stretched.
Old Oct 23, 2007 | 06:59 PM
imnothot02's Avatar
imnothot02
trying to picture, pic please?
