Paint
Old Oct 25, 2007 | 07:53 AM
imnothot02's Avatar
imnothot02
Default RE: Paint
buhhhhuuuullll $h!t you ever painted with a DIY gun?!!?
Old Oct 25, 2007 | 11:12 AM
halfbakedskillet's Avatar
halfbakedskillet
Default RE: Paint
thanks for the advice all. I was definitley going to get a water seperator. (I was probably just going to pick up the one avaiable at Home Depot or maybe one at my paint shop.) As for the gun, I double checked the exact spcs on the gun I'm getting against my compressor, and the compressor should be able to keep up, even if it means it'll be running a lot.
Old Oct 25, 2007 | 11:52 AM
Nicegy525's Avatar
Nicegy525
Default RE: Paint
best of luck. Remember, when you think youre done sanding, sand it again!!! a paint job is only as good as the prep work put into it. Over time the paint will settle and you may have some "shrinkback" if its not sanded right
Old Oct 25, 2007 | 11:56 AM
halfbakedskillet
Default RE: Paint
thanks, sounds like some good advice. I'm not in a huge hurry to get this done, so I'll take as long as it needs to get the prep done.
Old Oct 25, 2007 | 05:45 PM
imnothot02's Avatar
imnothot02
Default RE: Paint
bright light(s) help too
