03 4.7 stalling in reverse
Old Oct 24, 2007 | 10:34 PM
Nicegy525's Avatar
Nicegy525
Default RE: 03 4.7 stalling in reverse
I dont know if the ignition trick works on an '03. but I could be wrong. But if the problem is not throwing any check engine codes, then it most likely is something that is not monitored by a sensor. Have a tranny shop check for a bad torque converter. Cat could be clogged also.
Old Oct 24, 2007 | 11:06 PM
jimmers's Avatar
jimmers
ORIGINAL: Nicegy525
The igniton trick does work on an 03, it just says no codes after I do it. The truck is still under warranty so I guess I will take it in. It's just a hassle so I was wondering if it was somethingI could do on my own. Thanks for the help!
