Engine Code P0138
Old Oct 29, 2007 | 12:43 AM
w9awx's Avatar
w9awx
Default Engine Code P0138
Got a trouble code today while driving my Dakota normally. Did the old Dodge ignition test and Code P0138 came up on my odometer window.
P0138 (M) 1/2 O2 Sensor Shorted To Voltage Oxygen sensor input voltage maintained above normal
operating range.
That is my my service manual says it means. How do I track down what the problem is?
Old Oct 29, 2007 | 01:34 AM
varsis's Avatar
varsis
Default RE: Engine Code P0138
O2 might be shot.
Old Oct 29, 2007 | 08:10 AM
w9awx's Avatar
w9awx
Does one code cover all of them?
Old Oct 29, 2007 | 08:31 AM
4x4kota's Avatar
4x4kota
no this is bank one, sensor 2. (Drivers rear one) I have the same code.
Old Oct 31, 2007 | 11:23 AM
w9awx's Avatar
w9awx
My manunal shows that there are 4 O-2 sensors, one on each manifold and 1 before and one after the converter. How can there be a driver's rear sensor? Maybe I am mis-understanding your Driver's Rear statement.
Old Oct 31, 2007 | 10:46 PM
imnothot02's Avatar
imnothot02
there is 2 mans driver and pas
rear is post cat
do you have a truck with 4 o2 sensors? you may want to check not all of them do...i think just california trucks have four
Old Oct 31, 2007 | 11:07 PM
4x4kota's Avatar
4x4kota
silly me, i assumed all trucks had 4 O2 sensors cause mine does. Heres my setup, let me know if this makes more sense.
First of all you have a Y pipe that comes off of the manifolds right?
In this Y pipe there are 2bulges (Pre-cats)near the top, and a larger one in the rear.
If i remember correctly, there is a sensor before each pre-cat, and one after each pre-cat.
the one that is giving you the trouble is the one on the drivers side closest to the rear of the truck.
Does this help?
Old Nov 1, 2007 | 12:46 PM
User's Avatar
User
useally 01+ had the 4 o2 sensor setups, 97-00 didnt, but i think a FEW 2000 did. I know mine only has 2 o2 sensors and 1 cat, while the 01+ R/Ts and daks had 2 pre cats with 2 o2s for each, and one big cat with nothing around it.
Old Nov 13, 2007 | 07:45 PM
w9awx's Avatar
w9awx
Just an update. I am replacing the behind the cat oxygen sensor. Found a Denso sensor for $45 with free shipping. Was wondering if my K&N air filter would have caused the trouble code.
Old Nov 13, 2007 | 07:55 PM
wink2873's Avatar
wink2873
a k&n air filter wont affect anything.
