stalling
Old Oct 30, 2007 | 06:39 PM
98Dodger4x4's Avatar
98Dodger4x4
Default stalling
I have a major problem my 98 dakota keeps stalling out when im driving it. The check engine light isn't on and there no code. I have no idea what is going on. The truck runs fine and next thing you know the its stalls out when im at a red light on making a turn.
Old Oct 30, 2007 | 11:58 PM
steve05ram360's Avatar
steve05ram360
Default RE: stalling
crank sensor or the coil... one of the two have gone bad. there is an outside chance the fuel pump is also dying but I'd check the fuel pressure 1st right after it stalls... if it's above 45psi... that's not it.
Old Oct 31, 2007 | 07:51 AM
imnothot02's Avatar
imnothot02
think it could have to do with the IAC TPS ect.?
Old Oct 31, 2007 | 11:40 AM
Chris's Avatar
Chris
Is it having a difficult time starting?
Old Oct 31, 2007 | 04:09 PM
98Dodger4x4
after it happens it starts fine. It didnt do it at all today. I have no idea what the hell it wrong with it
Old Oct 31, 2007 | 10:43 PM
imnothot02's Avatar
imnothot02
wondering if its a electrical issue?!
Old Nov 1, 2007 | 03:59 AM
steve05ram360
ORIGINAL: imnothot02
nope, the IAC valve only affects it when it's close to idle... from his description, sounds like it's stalling as he's driving.
Old Nov 13, 2007 | 01:30 AM
viperkota's Avatar
viperkota
check the engine management relay under the hood in the fuse box...should be a 1"x1" black relay...about 9 bucks to replace
