tranny fluid
Old Nov 1, 2007 | 05:59 PM
highpriestess420's Avatar
highpriestess420
Any help as always is much appreciated!
Old Nov 1, 2007 | 06:45 PM
Chris's Avatar
Chris
Default RE: tranny fluid
http://www.allpar.com/fix/trans.html
Old Nov 1, 2007 | 07:50 PM
f0x672's Avatar
f0x672
put in dexrom/mercon and you might as well drop off your truck at a transmission shop and tell them to rebuild it... that fluid has a friction modifier in it to help with firmer shifts, mopar transmissions however are designed to slip a little when they shift, you will want to run mopar ATF+4, its synthetic, go to a dealership, stay away from walmart, thats the rejection batch that they can sell off, but the mopar atf has a mixture that helps conserve the life of the clutch packs and the seals to allow normal function
