funny fog light problem.
Old Nov 9, 2007 | 08:16 PM
threesixoh's Avatar
threesixoh
Default funny fog light problem.
Ok, so I hyave a very odd problem with my fog lights. They wont turn off! I can pull the fuse and they will shut off, but otherwise they will stay turned on, even with the switch in the dash removed ( the factory switch) or with the fog light relay pulled. Hell, I even pulled every single relay and they still stayed on.
So I'm thinking there must be a short somewhere, but where would be a good place to start looking?
[align=left] [/align]
Old Nov 9, 2007 | 09:06 PM
jonnymagnum's Avatar
jonnymagnum
Default RE: funny fog light problem.
do you have the stock fog lights or aftermarket. when I put my aftermarket fogs in they did the same thing. I guess they work off of a ground. so mine were grounding out on the frame. so I just stuck a piece of rubber between it and its been fine.
Old Nov 9, 2007 | 10:16 PM
threesixoh's Avatar
threesixoh
they are aftermarket, yes. they are also likely grounding to the frame like you said. But they way I have mine installed, it wont exactly be easy to take them back off to insulate them :/
I may have to make a new bracket out of something non-conductive instead of the steel bracket I fabbed up. Oh well.
Old Nov 10, 2007 | 09:17 PM
threesixoh's Avatar
threesixoh
I looked into the issue today, and it was indeed a ground related problem. I coiuldnt insulate my foglights properly, so I just used the wiring harness that the foglights came with. no big deal, I guess
Old Nov 11, 2007 | 12:13 AM
EricCartman's Avatar
EricCartman
Ifit were me...I would re-wire the switch so that it is between the light and +12V...
Cartman
Old Nov 11, 2007 | 02:07 PM
shrpshtr325's Avatar
shrpshtr325
THE ULTI-MOD
i would have done that from the start, but then thats me
