No Bus...code p1698
Old Nov 12, 2007 | 10:41 PM
lndrvrxj's Avatar
lndrvrxj
Default No Bus...code p1698
01' 4.7
My truck started to run rough two todays ago, then today it through code p1698. The truck starts and all gauges seem to work fine. I know the NO BUS means that there is No CCD Messages Received From PCM. Could this be a bad map sensor or CPS sensor. Has anyone had a similar problem. I am new to OBDII. What is the easiest way to narrow it down.
Old Nov 12, 2007 | 10:47 PM
imnothot02's Avatar
imnothot02
Default RE: No Bus...code p1698
PCM is fryed most likley try doing a reset disconnect neg battery cable ect. check for codes...
OR i know there is a TSB on the ebrake teeth grinding thru a wiring harness and grounding wires out causing a NO BUS message...
Old Nov 13, 2007 | 08:34 AM
lndrvrxj's Avatar
lndrvrxj
Explain TSB on the ebrake teeth?
Old Nov 13, 2007 | 06:11 PM
imnothot02's Avatar
imnothot02
the teeth grind thru wire (s) and cause them to short out...look up there and see if that is happining
Old Nov 14, 2007 | 09:02 AM
lndrvrxj's Avatar
lndrvrxj
A few other codes to add to list...
P0308 Misfire on Cylinder 8
P1687 No Cluster Bus Message
Hope this helps
Old Nov 19, 2007 | 12:47 PM
lndrvrxj's Avatar
lndrvrxj
Well I replaced the spark plug in cylinder 8 and reset all the codes, driven over 400miles and all is good.
Old Nov 19, 2007 | 07:31 PM
imnothot02's Avatar
imnothot02
even the no bus?
Old Nov 21, 2007 | 06:50 AM
lndrvrxj's Avatar
lndrvrxj
I guess that was just a burp in the computer scan.....don't know just one of those things I guess
