check engine light question..
Old Nov 15, 2007 | 04:13 PM
dualdakota01's Avatar
dualdakota01
Default check engine light question..
hey guys... so my check engine light came on today.. i did the turn on turn off thing... got a code... here's what is is:
P0442 (M) Evap Leak Monitor Meduim Leak Detected A small leak has been detected in the evaportive sysem
just curious what i should look for could be the problem here. everything seem sto run fine. just look'n for an idea of what i can check. never delt with this before thanks guys...sorry for the noooob question lol.
lata
Old Nov 15, 2007 | 04:23 PM
dualdakota01
Default RE: check engine light question..
so i just checked the search and found from another post that maybe some hosts under around the gas tank could be lose or the gas cap itself and seals maybe bad... .. any opinions?
Old Nov 16, 2007 | 08:25 AM
mplue's Avatar
mplue
I had a couple of hoses under the hood that was causing this problem for me. One hose came off the throttle body and don't remember where the other one went, but they were pretty close together and you could easily see they were cracked badly. I do remember that both hoses went to some sensor located just to the left of the battery (as you are sitting in the truck). I have also heard of the same thing around the charcoal filter near the gas tank causing this also. Hope that helps.
Old Nov 23, 2007 | 06:20 PM
moe7404's Avatar
moe7404
moe in wichita ks. i had a 1999 that i traded for a 2001. i had a locking gas cap on the 99 when i moved it to the 2001 the engine light came on. the threads are different and the seal is different. so a 99 gas cap will not work on a 01
Old Nov 24, 2007 | 09:27 PM
imnothot02's Avatar
imnothot02
try getinga new gas cap first, if it still comes up start checking hoses, mine were cracked under the fuse block under the hood (drawing a blank on what the thing is called under there..)
