cam break in?
Old Nov 29, 2007 | 01:51 PM
98whitekota's Avatar
98whitekota
Default cam break in?
dose any one know what RPM to break in a cam at i think that it is like 2500 but im not shur
Old Nov 29, 2007 | 03:58 PM
varsis's Avatar
varsis
Default RE: cam break in?
I found this quickly on the net.
http://yarchive.net/car/cam_break_in.html
Old Nov 29, 2007 | 09:20 PM
Sixtysixdeuce's Avatar
Sixtysixdeuce
Mopars aren't finicky like GM's. I usually fire it and let oil pressure build while I set timing (30-60 sec.), then hold at ~2,500 for 3-5 minutes, then let it idle until it gets to OT. I use blue bottle STP or Lucas for assembly lube.
Since you're dealing with a FI motor, you don't have to screw with timing, so just let pressure come up.
