idle problem...
Old Dec 3, 2007 | 04:33 AM
98whitekota's Avatar
98whitekota
Default idle problem...
i just cleaned my TB and when i started it it idled at like 1200 ( normal is like 700) and if i hit the gas peddle it will rev but then the RPM will not drop. it sticks at the highest RPM. my linkage is hooked up right, i just cant figure it out, and one had this happen. can any one help me PLEASE!!!!!!!!
Old Dec 3, 2007 | 09:58 AM
varsis's Avatar
varsis
Default RE: idle problem...
Sounds like a vacuum line got knocked off somewhere... or broken. Did you replace the gasket under the TB?
Old Dec 3, 2007 | 02:23 PM
Chris's Avatar
Chris
Make sure you hooked the vacuum line back up to the brake booster properly.
Old Dec 3, 2007 | 02:25 PM
Chris's Avatar
Chris
Ooops. That would be intake manifold. My bad. Make sure though that you are not getting a leak somewhere though. Try spraying brake cleaner or carb cleaner around the base of the throttle body and see if it revs up slightly when you do that. It means your gasket is leaking.
Old Dec 3, 2007 | 03:13 PM
jonnymagnum's Avatar
jonnymagnum
ya, it will be either the TB gasket or a vacuum line came off or has a hole in it.
Old Dec 6, 2007 | 01:29 PM
chris1974's Avatar
chris1974
Same EXACT thing happened to me. Took me a little while to figure it out....
When i was cleaning the TB, i removed the Air Intake sensor. Well, apparently the little plastic bar at the end of the AI sensor broke off, made its way down the throat of the TB, and got jammed in my IAC (or was it the TPS?). I would suggest pulling the sensors and checking them out. You could give them a good cleaning while your at it..
Old Dec 6, 2007 | 03:29 PM
steve05ram360's Avatar
steve05ram360
you may have not lined up the tps correctly during the install, take it out and try again. I did this along time ago on my 2000 ram and realized it when the motor reved over 1000 rpms... check it out when you do the vacuum searching..
