Need warmer air?
Old Dec 13, 2007 | 05:45 PM
robles4242's Avatar
robles4242
Default Need warmer air?
Why is it my heater could freeze water even after its warmed up. I mean yeah you can tell the heats on but.. Its not as warm as it should be evemn on full heat and full power. My ac was never that Cold either... Please help...
Old Dec 13, 2007 | 06:39 PM
skeeter0288's Avatar
skeeter0288
Default RE: Need warmer air?
what temp is your thermostat?
klings designs's Avatar
klings designs
You may need a new thermastat!
I dont think that is the word i am looking for... It is in your coolent lines next to your water pump... SORRY JUST WOKE UP!
Old Dec 13, 2007 | 06:50 PM
robles4242's Avatar
robles4242
Its a 180. Brand new. i changed it with my waterpump and bypass hose.
Old Dec 13, 2007 | 06:52 PM
klings designs
Did the cold start happening right after you changed it?
Old Dec 13, 2007 | 06:57 PM
robles4242's Avatar
robles4242
I changed it in summer so i dont recall. A Buddy of mine says something about a bleeder line that could be bled that causes this? I dont know im the furthest thing from a mechanic....
Suggestions? Things to check?
Old Dec 13, 2007 | 07:00 PM
klings designs
is your temp around 180 otherwise i was going to say, that maybe it is a bad thermostat....
Old Dec 13, 2007 | 09:00 PM
robles4242's Avatar
robles4242
My temp gauges are all where they should be if thats what you mean...
Old Dec 14, 2007 | 12:04 AM
f0x672's Avatar
f0x672
flush out your heater core, sounds like poor circulation, theres a how to sticky note ontop of the dakota 2nd gen forum
Old Dec 14, 2007 | 04:00 PM
varsis's Avatar
varsis
second that, I had the same problem. Flushed it out. Make sure you do a good job, and flush the whole system too. Otherwise it will clog right back up. Mine never heated, did it once, heated for 3 days than it plugged back up flushed in summer 3 times to make sure it was good. This time It still works.
