1997 Dodge Dakota Power Steering Problems
Old Dec 29, 2007 | 01:43 AM
Artus's Avatar
Artus
Default 1997 Dodge Dakota Power Steering Problems
While driving home the other nightI lost power steering all together. I don't have power steering fluid on the ground where I park, the belts are all intact, and the pump was not making any weird noises. I have power steering fluid. Tonight it "feels" like the steering is getting harder also. Any ideas? No check engine light is on.
Truck is 1997 Dakota Sport, 4x4 5.2liter.
Old Dec 29, 2007 | 11:48 PM
wink2873's Avatar
wink2873
Default RE: 1997 Dodge Dakota Power Steering Problems
slipping belt maybe? check to make sure the pump hasnt actually quit.
Old Dec 30, 2007 | 01:21 PM
pwdrhaulr's Avatar
pwdrhaulr
Just because there's no blood on the ground don't mean it ain't bleeding on the inside. Have the system pressured check to see if the pump is pushing fluid. When you checked the fluid, was it a pale blue color and still somewhat clear or was it black and cloudy? I'm leaning towards the pump bit the big one but don't rule out the steering box either, There's a check valve internally of the steering box that could be stuck on thehighpressure side not allowing the pump to push the steering box.
Old Dec 30, 2007 | 03:17 PM
Chris's Avatar
Chris
Make sure the P/S pump isn't seizing
Old Dec 31, 2007 | 11:21 PM
moe7404's Avatar
moe7404
Moe in Wichita Kansas
What ever you do DONT flush the pump with solvant. use steering fulid.
