stereo removal
Old Dec 30, 2007 | 05:19 PM
magic624's Avatar
magic624
Default stereo removal
how do you remove factory stereo from 2001 dakota? mine is toast....
Old Dec 30, 2007 | 05:24 PM
magnethead's Avatar
magnethead
Default RE: stereo removal
very easy. Put your right hand under the dash panel next to the pass air bag defeat switch, and pull. Then pop your finger under the panel by the left side of the AC controls- pull. And again at the left next to the dimmer *****. And thats off. then unhook the airbag switch (dnt worry about them going off, i unhooked the batt anyways though) and AC control harness, tilt wheel down, pull shifter to 1st gear (dont need the key- see recall), lift panel over wheel, and set on top edge of driver door while it's open. Then radio is 4 bolts and either 1 or 2 harnesses.
Old Dec 30, 2007 | 05:50 PM
magic624's Avatar
magic624
no screws or bolts to fuss with on dash panel? i dont have airbag defeat switch on mine, assume i go to where it would be and.....pull?
Old Dec 31, 2007 | 11:19 AM
magnethead's Avatar
magnethead
right. It's all pop clips, they aren't like door panels so dont worry bout breaking them (they wont break), just go down there and start pulling. I'd say the hardest part is getting it out from the steering wheel/guage cluster area. There's a gasket there you have to avoid tearing, then get it back in straight. I got mine out alright, getting back in, the left sid vent and light switch didnt agree with me, i got the cluster are in but the gasket kinda folded up, once i got those straightened up the rest was cake.
Old Dec 31, 2007 | 01:33 PM
magic624's Avatar
magic624
hey thanks for the info......i will give it a try....eric
Old Dec 31, 2007 | 02:55 PM
magic624's Avatar
magic624
i got the dash panel loose, but am having some trouble with the ac harness-how do you get that sucker off? is there a clip or something or do you just....pull?
Old Jan 1, 2008 | 02:32 PM
magnethead's Avatar
magnethead
IIRC there are some retaining clips on 2 side of it, believe you have to pop those loose then they should come right off. They should eb the kind that are flat and have a slat in them that a hook on the controls grabs. You just pop that clip up and slide back
Old Jan 1, 2008 | 04:05 PM
magic624's Avatar
magic624
thanks much....i will try.....
