Groaning noise...Power Steering?
Old Jan 1, 2008 | 11:34 PM
rhodan's Avatar
rhodan
Junior Member
Default Groaning noise...Power Steering?
When I start my truck up in the morning it sounds and drives great....As it warms up though it starts having a loud groaning noise, especially when I'm turning...Meaning the groaning getsworst. I checked my power steering fluid and there is a small leak, but steering never gets tight or hard to move. I top it off about every 10 days or so...Andit is a groaning noise not a squeak or asqueal...I wanted to check to see if anyone else has had this issue ordoes it sound likeonce I replace the steering pump it will resolve the groan?
Thanks.
Matt D.
2000 BLK Dakota R/T CC
Old Jan 2, 2008 | 04:39 PM
MTN13's Avatar
MTN13
From: Hometown= Highland Michigan School= Lima Ohio
Default RE: Groaning noise...Power Steering?
Sorry i do not have a soultion for you but mine does the exact same thing, it has done it for about two months and i have done everything i can to stop it but nothing seems to help. The only thing that is diffrent is that mine does not leak at all.
Old Jan 6, 2008 | 01:30 PM
rhodan's Avatar
rhodan
Junior Member
Thanks....I was afraid of that....A mystery noise.
Matt D.
Old Jan 6, 2008 | 02:34 PM
imnothot02's Avatar
imnothot02
ur pump is on its way out, you ever flush the fluid in ur powersteering system? This needs to be done just liek any other fluid in your truck... every say 30-50k depoending on city/highway driving.
Old Jan 6, 2008 | 06:42 PM
moe7404's Avatar
moe7404
groning may be dry balljoints
this is a capture and paste
Moe in Wichita Kansas
May be air lock in pump or steering gear. Flush pump by taking off the belt , and take offthe high pressure hose so you can catch fulid comming out of the pump, turn the pump by hand and keep adding fluid so it doesnt go dry. what ever you do DONT run solvent or any other light fulids in the pump, it must have regular fulid only. [align=right]
[/align]
Old Jan 7, 2008 | 03:18 PM
cooki97223's Avatar
cooki97223
my truck does it too, i dont think anything is wrong with it though.
Old Jan 9, 2008 | 11:50 PM
rhodan's Avatar
rhodan
Junior Member
I'm hoping this weekend I will have more information....I'm going to change out the belt, bearing(s) and the powersteering pump and hopefully this will solve it...
Thanks.
Matt D.
