Heater fan only runs on high
Old Jan 4, 2008 | 03:55 PM
utah patriot blue's Avatar
utah patriot blue
Default Heater fan only runs on high
The fan on my2001 Dakota Crew cab 4.7L only runs on high. Checked the fuse, and it's ok, and it seems to not be sending the air to theright places(defrost, floor, dashboard). Anyone have similar problems like this? Could it be a vacuum problem, or does it sound like an electrical problem?
Thanks to all!
Old Jan 4, 2008 | 06:27 PM
wink2873's Avatar
wink2873
Default RE: Heater fan only runs on high
its an electrical problem, the same exact thing happened to my 2001. I got it fixed at the dealership under warranty but for the life of me i cant remember what it was called... sorry.
Old Jan 4, 2008 | 08:17 PM
olsarge's Avatar
olsarge
Blower resistor. About $30 and easy to do it yourself. Mounts into the housing above passengers feet. 3 screws I think.
Old Jan 4, 2008 | 08:42 PM
wink2873's Avatar
wink2873
that was it... thanks olsarge. that happened to me a couple years ago in the dead of winter. it got really annoying only having high heat.
Old Jan 29, 2008 | 05:24 PM
utah patriot blue
Thanks for your help. I bought the part, located the resistor blockk and spent 45 minutes trying to get the quick connect off. There seemed to be a red retaining clip in the plug that I removed, and still could not get the D#%! thing off. Any tips?
Thanks.
Old Jan 29, 2008 | 07:18 PM
imnothot02's Avatar
imnothot02
you dont remove it pull it back a 1/8 inch and pull it off..
Old Jan 29, 2008 | 07:56 PM
rtkota5point9's Avatar
rtkota5point9
Yup, this is a common problem on ANY vehicle. The red clip should slide outthe side a bit, then pres the release down and pull it out.
Old Jan 29, 2008 | 11:31 PM
ccrunner's Avatar
ccrunner
Those damn connectors witht the red slide! I had the same problem when I try to unplug the control cluster in the driver door, and once I got it out I had to use a screwdriver to reset the red slide.
Old Feb 4, 2008 | 01:21 PM
utah patriot blue
Thanks! I've never had anything so small give me so much grief!!!
