Tire Pressure
I did a couple of different searches using different ways of saying tire pressure. The only things I saw were about making sure your tires were properly inflated. I am looking for what tire pressure I should put my new tires at. The door sticker only shows the 2wd tires, p215/75r15. It says to inflate to 35psi cold. I have P235/75R15 all terrain tires on it now. The sidewall says maximum load at 41psi, which is what the tire dealer inflated them to when they installed them. What pressure is correct? I assume 35 would be better for off-roading but 40psi would be better for mileage. Help?
Thanks in advance.
Thanks in advance.
Hello from va,that is just it everone has a didnt opion,and that good I talked to my tire rep,and they are putting the max safe psi and that is what i do.my max is 41 i changed it from 35 to 40 psi cold,make sure the tires are cold not warm I changed my plugs that had 50,000 on them and went from 280 miles a tank to 380.A low tire is hard to get going {just my 2 cents}[&:]
