changed battery now got probelms
Old Jan 10, 2008 | 09:22 PM
kld1077's Avatar
kld1077
Default changed battery now got probelms
i went out side one day and my truck would not start, batterywas dead, went to auto zone and bought a battery and now I am having problems with the 2001 4.7L dakota shutting off, if let it run for about5 or 10 minutes it will just stop no CEL code either, need some insight on this problem, i was told by a dodge dealship that it might be the IAC, changed it and still have the same problem, so far I have changed the TPS, Camsahft and Crankshaft Sensors....what next, could it be the battery because I did not have this problem before I changed it and why would it be the battery?
Old Jan 10, 2008 | 10:09 PM
wink2873's Avatar
wink2873
Default RE: changed battery now got probelms
your alternator might not be charging the system... have it tested.
Old Jan 11, 2008 | 08:08 AM
4x4kota's Avatar
4x4kota
It is apossibility that it's the battery. First check the cables, make sure you have good connections. If that dosn't do it i'd take the battery back and have it tested. Then if still no luck I'd test the alternator. Try the easy stuf first...
Old Jan 11, 2008 | 07:39 PM
magnethead's Avatar
magnethead
if the other battery was dead, i'd say check the alternator. Although i'd like to think it would run for longer than 10 minutes on batt only, esp with a V6?
Old Jan 11, 2008 | 08:05 PM
wink2873's Avatar
wink2873
newer vehicles wont last 10 minutes with only the battery because all the accessories suck up so much power.
Old Jan 12, 2008 | 10:15 PM
skeeter0288's Avatar
skeeter0288
i got a battery from pep boys a few years ago and ended up taking it back because it was shorting out inside.had to turn around and do it again because the second batery was doing the same thing.i think advance auto will check the battery and the alternator for you at no charge.
Old Jan 12, 2008 | 10:52 PM
wink2873's Avatar
wink2873
yea, just because it's a brand new battery doesnt mean it's going to work properly. I've seen a brand new battery fail twice.
Old Jan 12, 2008 | 11:26 PM
4x4kota's Avatar
4x4kota
Thats what I was getting at. I work at a parts store selling parts to people, and we occasionaly do sell a battery that comes back faulty. It's not very common, but it does happen. And we also do free alternator and battery tests.
Old Jan 13, 2008 | 01:26 PM
magnethead's Avatar
magnethead
ORIGINAL: wink2873
wow- my dually has the 454 and it's bulletproof. I've driven it 200 miles on minimal if any antifreeze, and i know once we drove it 30 miles with the alternator belt kicked. And it has an HEI 454.
Old Jan 13, 2008 | 01:55 PM
imnothot02's Avatar
imnothot02
my jap subaru runs with no battery, did it just yesterday jump and go! lol
