Oil pressure!!!!!!
Old Jan 21, 2008 | 01:24 AM
trjnrstlr07's Avatar
trjnrstlr07
Default Oil pressure!!!!!!
hey I have a 99 5.9 it has 105,000 miles on it,... ok my problem has bin happening for a about a week now, the oil pressure gage in my truck just suddenly drops from around the middle 40 to 0, it doesnt slowly drop so I dont think its a major problem but Im not to educated in the auto area... but like I sed the niddle drops randomly when I drive. I dont think its a big problem cause to me it seems its a sensor issue, what you guys think??? thank for replys
Old Jan 21, 2008 | 09:06 AM
kjun's Avatar
kjun
Default RE: Oil pressure!!!!!!
Check the oil level. Pretty common for this to happen when its low.
Old Jan 21, 2008 | 09:31 AM
rtkota5point9's Avatar
rtkota5point9
Very true, but when it's low it usually only happens when coming to a stop or decellerating. Not while just driving. But definatly check it anyways.
Old Jan 21, 2008 | 09:37 AM
varsis's Avatar
varsis
Probably just a loose wire somewhere, even a ground one can cause this. This happened to me awhile back and I found a loose ground wire fixed it right up.
Old Jan 21, 2008 | 09:41 AM
4x4kota's Avatar
4x4kota
could be the oil pressure sensor on the fritz.
Old Jan 21, 2008 | 07:41 PM
imnothot02's Avatar
imnothot02
the pin hole in ur sending unit is pluged, get a mechanical guage IMO the dash gauge is worthless...
Old Jan 22, 2008 | 01:01 AM
trjnrstlr07
hey yea I checked the oil level and it was low like WAY low.[>:]... and I dont know why it would be I got the oil changed in about a month back, I would think it would have a lot left in it.... theres no leaks or anything that would show me that I lost oil. so new question for me to ask... where the hell did it go? or what happend to it?... I put in about 2 qrts and it fixed the beeping sound but the needle still drop a lil below normal so Im just goin to go get oil put in it. but yea I still dont know what happend to the recent oil??
Old Jan 22, 2008 | 08:18 AM
imnothot02's Avatar
imnothot02
my 02 4.7 looses a quart every 3000 or so, its a dodge thing, my jeep does the same thing, thats a 5.2
Old Jan 26, 2008 | 05:49 PM
w9awx's Avatar
w9awx
Thus check your fluids at least once a month. j/k
1qt per 5000 mile oil change is normal in just about any vehicle. Some just lose less.
Old Jan 27, 2008 | 01:28 AM
00DakR/T's Avatar
00DakR/T
If your truck hasn't ever had the intake pan TSB done, you may want to watch the oil consumption to see if it is alittle excessive.
