heater controls
Old Jan 25, 2008 | 10:02 PM
corri's Avatar
corri
Default heater controls
my floor vent on the passenger side doesnt blow any air at all. the driverside works fine. is there a vaccum line on these or what? thanks in advance
Old Jan 26, 2008 | 11:49 AM
imnothot02's Avatar
imnothot02
Default RE: heater controls
yes sir
Old Jan 26, 2008 | 11:34 PM
corri's Avatar
corri
thats maam if you must. and can you possibly tell me where i should start looking? do i need to tear the dash apart?
Old Jan 27, 2008 | 11:02 AM
imnothot02's Avatar
imnothot02
oh my bad[:-]im no pro in that area
Old Jan 27, 2008 | 06:45 PM
master tech's Avatar
master tech
Site Moderator & Tech
Have someone turn the mode **** and someone else look at the actuators and see if they move. Or apply vacuum at the actuators. You could have a broken bleed door or actuator.
Old Jan 28, 2008 | 12:49 PM
corri's Avatar
corri
i had a similar problem with the defroster not working, i had the "gauge ****" cluster for the controls replaced. it worked for awhile. im not sure where the vaccum lines are. it doesnt show them in my haynes manual. i guess i'll take it to the garage. thanks for your help.
